Bugger, I should have said that to Toyota Bristol when I hit their wall.My two cents worth, ABS does not improve braking, it prevents your brakes from working.
Twice i've seen a child fatally hit by a car , both in a 30mph zone and both drivers slammed on . Both drivers were blameless . I got told off by my the instructor during my driving test for coasting with a foot on the clutch and the other on the brake , i said there's a kid on a pushbike in front of that parked bus aiming to cross the road . I don't like abs because if i hit stop i don't want the car to reply "yeah in a minute" .
would be nice to have a switch to turn the abs off when you want to play
cheers
is that 'switch' accessible to parallel another switch inside the cab?
[Shane quoted] Bikes have always had abs - its called a gearbox when you come around a corner and find a tractor trailer crossing the road from one field to the next you crash down the box while applying as much brake pressure as you dare while choosing a point of impact that might allow you to survive.[Unquote]
It is my understanding that if you ‘crash down the box’ you risk the rear wheel locking? I have no real knowledge of motorbike gearboxes but would have assumed the sudden drop in ratio against the compression of the engine would have created an ‘engine braking’ scenario and perhaps aggravate the possibility of a rear wheel lock up? Someone with more knowledge would need to help me with that so I have to reserve judgment at this time.
In low range ABS is switched off, is that 'switch' accessible to parallel another switch inside the cab?
I really do think someone needs to find a way to modify the ABS to interfere less and let the breaks break harder before cutting in...hmm thoughts?
I'm assuming you mean switching off the ABS without locking the CD? The short answer is no but I dare say something could be wired in. If I understand the setup correctly the difflock ECU sends a signal to the ABS ECU when the CD is locked, disabling ABS. You'd have to locate the wire(s) used to send this signal and wire in a switch in the cab. You'd also need to know what the 'signal' is, earth, +12v or maybe some other voltage?
Another possible way of doing it would be to wire in a switch from the fused supply to the ABS ECU so you could cut the power to it which would amount to pulling the fuse which some seem to do to disable ABS permanently........maybe???
Don't want to sound like an old woman but would this not have insurance ramifications?
JMO
