tony rodaway
- Aug 28, 2016
got an lc90 3.0 td 98 model just wanna no the best way to get air out of the fuel system .
I changed the spring in the banjo bolt on the fuel pump return valve and must have got air in when i put it back together.
been told to prime the fuel filter and open injection valves one by one but only problem is the forth valvle seems hidden away behind the inlet manifold.
my question can it be bled with just 3 valves if the front of the car is raised
im no machanic so just want advise on best way forward.
CAR SYMTOMS
HARD TO START JUST OFF THE KEY AS NEED TO PUMP THE GAS PEDAL AND STARTS AND DRIVES OK.
CAR SYMTOMS
