so i got the bolt welded into the 4th leg.
spun a nut down each leg.
and cut off the protruding thread.
i was trying to think of a way to mark the position of the pigs legs on his belly. its difficult to mark something thats curved and rounded both ways.
so i decided to use a piece of paper.
positioned it on the pig and marked each corner.
i then centre punched each pen mark, before cleaning all the paint off ready for welding.
positioned a nut central to the centre punch mark, and then tack welded it on.
did this to another 2 legs and then decided to screw the legs on and see how the pig stands.
really wasnt happy with how the pig was sitting/standing at this point. the legs were far too splayed out apart, and the door wasnt level, so kept swinging shut.
time to sit, look and think, with a cold beer of course.
this is how far out of level it was for the door to be right.
so all the legs back off and old welds removed.
needed to move the bottoms of the legs in bit, so i welded 4 bolts to the bench top. the idea being the legs would fit over these bolts and be held in place.
i then hung the pig above the legs and tried to position it over the legs.
this wasnt very successful as i needed 6 pairs of hands to hold and weld everything.
next idea was, to make a square that could be clamped to the top of the legs and hold the tops of the legs in position while the bottom of the legs were held on the bolts welded to the bench.
so knocked up a square out of some scrap 10mm bar.
this idea didnt really work as i couldnt clamp the legs without the clamps jumping off.
been super busy so not had chance to look at it or do any on it for a week now, but im really struggling to work out the easiest way to weld the legs on at the correct angle, and position. any ideas?
