- Jun 30, 2011
Sounds like a loose connection to be honest.. if it works sometimes and not others that's most likely. I robbed some connector pins out of an unused connector behind the dash and fitted them to the end of the wires and slotted them into the white connector behind the airbag unit. If these were not tight it could be the problem. Mine has been perfect, and I use it every day.
Enjoy the vino!
Enjoy the vino!
