- Dec 23, 2016
Yes I did
As written above
You spend your money on an Oil catch can delete the EGR cause it bungs up the intake with unburnt oil and assorted other crap then you put in some two stroke OIL designed for petrol engines upper cylinder lubricant into the diesel tank where it goes into the diesel engine to be burnt and the byproducts of the said oil go down the exhaust pipe and some into the Oil catch can this seems pointless to me after the work done on the engine to reduce the oil going back in the engine system
or is it a type of replacement for the sulphur reduction of these modern fuels to lubricate the upper drive train of the engine and keep clean after reading previous posts some believe in off the shelf products some believe in none and some swear by two stroke which does not sound so bad
As written above
