LJ70 Build Thread!
Another late night last night to get the cruiser ready for today, when I was hoping to get it registered and on the road. :icon-smile:
Wanted to get the flares and mud flaps fitted on the drivers side, but there was a couple of tiny bits of rust to sort out first.
Rear arch.
front wing.
Ground it back and then sprayed it with dinitrol rust converter.
Got it painted.
Theyve got a nice big MIG welder here which I used to make a mud flap bracket.
Drilled some holes in it.
Sprayed it black and bolted it on.
Mud flap on.
Got the flares on next.
Had to take the rear wheel off to screw the rear flare on.
I then pulled it outside and gave it a good wash with the big diesel heated pressure washer. :icon-cool:
So today I set off at 7.30am and got to the Vic Roads branch for my 9am appointment only to be told I needed to get it inspected by an engineer who would sign the import approval form to say the vehicle complies to Australian standards. :doh:
They printed me off a list of all the places I could take it to. So I called a few and arranged to take it over to one of the places.
2 hours driving later I got there and they had a look over the Cruiser. :|
First FAIL...............................
Seat belts. 1 was missing the little label that is sown to the bottom of the seat belt. The other side was slightly worn. :icon-rolleyes:
Headlights next...........A tiny bit of mud/rust inside the lenses.
Spare wheel is obscuring the drivers side light slightly. :icon-confused:
Then they spotted the seam of weld below the windscreen which I never got round to grinding down, filling and painting. :oops:
So after explaining that it was from a rust repair, because 70's always rust below the screens on UK 70's, and its quite a common thing to have to weld along there. :whistle:
So they gave me a list of things to sort out.
New headlights and seat belts. Remove the spare wheel and fix the rust repairs. :think:
I stopped at a 4x4 wreckers yard on the way back. Pair of headlights from a hi-lux (fingers crossed they fit. :pray:) for the bargain price of $30 (£20) the pair. :icon-biggrin:
For a pair of second hand seat belts they wanted $300 (£200) :shock:
So obviously I left with just the headlights. Going to see if the seat belts in the farm hilux are any good, and might borrow them for mine. :think:
So its not going to be on the road before this weekend, as I also need a compliance sticker which will take about a week to reach me. :thumbdown:
Does it not need a compliance plate Ben? I'd have thought that VICRoads will be looking for one... if it does need one then you'll need to pay through the nose for that as well...
Hopefully not Ed. :icon-wink:
From my experience over here its all about who you know, not what you know. If this wasnt a public forum, youd be amazed at some of the things I could tell you have gone on over here with everything. :shhh:
Seat belts. 1 was missing the little label that is sewn to the bottom of the seat belt. The other side was slightly worn. :icon-rolleyes:
Sorry Ben (ducking for cover from the incoming bashing for being a smart arse), but you did need that compliance plate that I thought you would... It's impossible to rego a vehicle without one unless it is pre-ADR of 197x... some things are unavoidable...
If you loose the Compliance Plate it's impossible to register it as a new owner, as it wouldn't pass inspection.
Have you asked Mr T how much for some new seatbelts, sometimes the breakers can take the piss a bit with their prices... and if the build date on the seat belt is much older than your vehicle build date then I think they might get cross...
The guy who has been advising me got it wrong. Hes used to importing older cars, where no compliance sticker is needed. :thumbdown:
Good luck with all that Ben. Still enjoying your thread of course. :techie-studyinggra:
Cheers John. :thumbup:
Pre ADR's are a lot easier, and whole lot easier to modify as well... there is no need to make sure they meet any of the ADR regs in terms of all sorts of things! Emissions is the big one that is outside the rules, but things like engine and brakes are still under the remit.
The ADR's are quite strict, and have some interesting rules that have led to a lot of work (like that Honda you posted before with the additional door bars-does yours have them as a thought? If not it would be easiest to get a set off of a 70 at the breakers)
Good Luck with this next stage! Once that's done it'll be a breeze... But in the meantime does this affect it's Un-Registered vehicle permit status as it doesn't (have the evidence that it) match the ADR's?
The compliance plate is like a chassis/VIN plate on the bulkhead/structural part of the bodywork. Is it going to be going to a vehicle "manufacturer" or is it going to someone who does the import inspections for personal imports? I'm guessing from what you've said it's going to someone who does vehicle inspections, rather than a "manufacturer"; the "manufacturers" tended to deal with HiLux Surf's and Terrano's from Japan when the rules were a bit slacker than they are now.
I've just found that I can head to Aus at any time, but we (GF) can't start work until I start uni at the end of June; already started looking at places to live and cars to buy... can't justify another 'Cruiser, but looking at a 4Runner instead
I mentioned the idea to a friend who owns and runs a 4x4 garage over here and this was his response:-
The old change-over switch concept is very old school and such ‘budget’ measures are not ideal.
Firstly, people forget and that causes dramas after a long drive and no charge in the second battery, or they drain both when stationary.
Secondly, they potentially introduce surges into the electrical system when connecting due to differences in voltage potential when switch under load and there is no means of surge protection built in.
Its just not worth it. In more modern vehicles it can actually fry ECU’s.
Leave that suggestion to the history books I’m afraid.
:think:
Interesting. I can't say I've had any troubles over the 3 years I've had the system fitted. Forgotten to remove the key once or twice when parked up but no drama's as I remembered long before I drained the main batteries past the point of being unable to start again. Not too sure how surges could be introduced.., maybe if you were running something off the leisure battery while driving and then suddenly turned the kill switch you might damage whatever's running off it, but I certainly can't see it happening the other way 'round. I'll keep in mind the comment about frying the ECU and won't fit the idea to a vehicle that runs off one.
Does your friend by any chance sell split charge relays?
Ed, one of the 4 import approval forms is for obtaining the compliance sticker. The guy signing and stamping the compliance forms has sent off for the sticker and that will be sent directly to me.
He has kept the rest of the import approval forms, and once I've corrected the few issues he wasnt happy with I need to take it back to him and pay him $250 for doing the inspection and $85 for the compliance sticker.
Then I can go back to Vic Roads and they can register it on the road.
Unregistered vehicle permit is still valid, as its designed so you can move the vehicle around while getting it road legal.
But it runs out on Wednesday so I'm going to have to buy another one. :icon-biggrin:
Fair enough.
Doesnt yours have an ECU though? :think:
He does sell split charge relays amongst other things, but he loves helping people and offering advice. Hes not pushing for a sale at all and is a great guy.
Ask Tony S or Scott, they will tell you what a great guy Chris at FNB is. :thumbup:
Wednesday I worked 8am till 6pm driving tractors. :icon-cool:
Few pics of my truck in daylight with the new flares and mud flaps. :icon-biggrin:
I then came back and worked till midnight on the truck. :sleeping-sleep:
Decided to get the headlights changed first (not that they really needed changing, but oh well.........at least I've got a spare pair now.)
The screws were rusty and very hard to get out. Ended up having to use mole grips.
The replacement headlights which are from a hilux are both slightly different, but one was the same.
Other one was slightly different but still fitted perfectly.
This is the supposed rust/damage. :icon-rolleyes:
Method for removing the rusty 20 year old screws/bolts.
When I fitted the bumper indicators I also soldered on some wires for the side lights (red and black wires in the pic below). At some point I want to wire these to the sidelights.
Snorkel took a hit the other day when I was driving round the showground and an over hanging branch ripped the grill clean off.
Fortunately I upgraded to a metal one, so it can easily be bent back when damaged. :icon-twisted:
Used a hammer and anvil to straighten it.
This is the rust repair weld that needs sorting out. Had it not been so bloody cold in the UK before I left this would have been done.
Bonnet removed.
Found MORE Lincomb sand inside the bonnet when I removed it. :icon-surprised:
Admittedly the weld looks shit. :thumbdown:
In my defence it was MIG welding outside on a very windy day. :oops:
Spotted these in the workshop and thought they looked perfect for this job. :icon-biggrin:
Rubber sheet to protect the new screen.
Air grinder.
Put a sheet across the engine to catch all the horrible bits of swarf.
Spotted a big industrial style vacume cleaner, which worked well for sucking up any bits of swarf that didnt land on the sheet.
Used a magnetic tipped screwdriver to get the last few bits which fell in behind the bonnet hinge.
Mixed half the filler with half the catalyst in the pic below and soon realized this was far too much catalyst. :oops:
Think I must have been used to the UK conditions and had forgotten it was 30 degrees inside the workshop. :icon-cool:
Filled.
Sanded down the filler.
Painted.
Bonnet back on.
Had a lovely evening and day with Laura! :dance:
Came home this afternoon and decided to get the seat belts removed so I can try and get some more tomorrow morning.
Emptied all the tools out of the back.
Removed the angle aluminium trims and discovered quite a bit of mold when I pulled back the rubber mat. :thumbdown:
6-7 weeks in the shipping container must have caused that. :doh:
Removed the ply from the top of the drawer system.
This then gave me access to the side panels/door cards that I needed to remove to get to the seat belts.
Panel pulled off I could unbolt the seat belts.
Belts removed.
So one of the belts is missing the orange label, and apparently the belts are worn, meaning they would be unsafe in a crash. :icon-rolleyes:
I called round a few Toyota wreckers on Wednesday, but non of them had any bundera (OZ version of LJ70) in stock. :thumbdown:
I did look at the ones in the 70 ute, but they looked different. I'm going to have a proper look tomorrow now I've got mine off to compare them to. :think:
Bloody annoying because I'm sure the ones in the 70 the roof came off would have been mint. Johnie fancy sending them over mate? :lol:
Plan for tomorrow is go get some seat belts and a few bits of camping gear and then get over and meet up with all the guys/girls and kids who are on the camping/4x4ing trip. :icon-cool:
So with that in mind, I needed to get the proper tyres fitted! :dance:
No need to struggle carrying stupidly big 37" tyres around anymore! :violin:
I want to replace the suspension and give it more lift. I'm not happy with the sagging +2" ironman lift.
Might fit some chains to hold the mud flaps away from the tyres a bit. :think:
Looks much better!!! :clap:
The workshop here is so awesome!!!!!
Every tool I could wish for,plenty of space, can get the truck inside, and best of all its far away enough from the main house that I can hammer, bang and grind all night long and not disturb anyone. :dance:
If all goes to plan tomorrow, expect some pics of me off roading the LandCruiser very soon! :icon-cool:
Great stuff Ben,
Keep on pluggin' away.
Can't you just "find" an orange label and sew that back onto your seat belt?
Gra.
what about the seat belts out of a troopy or even a hd 70 but with the same style body ie swb ?
Yes it can be very annoying for the neighbours when I'm banging and grinding away all night, ooh er missus :laughing-rolling:
Ben did you try asking for a seatbelt for a:
-middy (not the little beer)
-Bundy (not the rum)
-73 or 74 (BJ or FJ)
I'd be surprised if one out of the Ute or the Troopy didn't fit as well; I suspect the seat dimensions are very similar.
If you're still not having any luck I know someone in NSW who may have a suitable belt from another Bundy as he has had a few over the years.
I hope you have a minerals licence for the importing of that sand, Ben. They're quite particular about that so I hear.
C
Great stuff Ben,
Gra.
:thumbup:
I did think about it Gra, but they said the other belt was worn/old so they both needed replacing. :icon-rolleyes:
I had great contacts for the bonded warehouse, road worthy certificate, and which Vic Roads office to go to. Which meant it was a complete breeze.
But I didnt have a contact for the compliance certificate, and the guy I went to seems to be a bit picky. :(
Thats what I ended up doing in the end mate. :thumbup:
:lol:
Sorted now thanks mate. :thumbup:
C
:lol:
Dont think I will ever see the last of that Lincomb sand. :|
Your ment to be off roading :icon-biggrin:
I was and it was awesome! :dance:
Update to follow. :icon-wink:
So Saturday morning I spent 4 hours driving round trying to get seat belts. :thumbdown:
In the end I went to the other side of the city to what can only be described as the best Toyota scrap yard I've ever seen. :clap:
A huge warehouse with 15 brand new 4 post lifts/ramps in a row all with different cruisers and hiluxes on being stripped for parts.
They then had the orange and blue warehouse racking 20meters+ high with walkways/floors between each level all full of cruiser parts. :icon-biggrin:
They took the seat belts out of a 3 year old 70 series pick up (ute) that had been rolled, as they couldnt find any on the shelf.
After much battering with the guy who I think was Lebanese I got them for $300. Much more than I wanted to pay, but much better than the $400 he wanted. :icon-smile:
The new one is slightly different but fortunately it fits OK in my truck.
I did also get the other bits, as my seat belt wouldnt click into these in the donor 70. But the stalks are too short to fit in my truck, and as they came out of a 70 with a bench seat, the belt only fits into the loose buckle which isnt on a stalk.
Started loading the camping gear in. The new self inflating double air matress would prove to be very comfortable and warm. :clap:
And off I went.
I had no address and non of the 3 map books I've got had enough detail to show where I was going.
But some how I navigated the 50mile trip there using some rough notes I made using google maps. :icon-cool:
Just oven an hour to reach the property.
I drove to the forrest, but thought I must have gone the wrong way because the tracks ahead looked extreme, and I knew the club was towing a toilet trailer in and didnt think there was anyway they could have come this way.
So I turned around.
After managing to get in touch with one of the members, he confirmed I should have continued through the forrest.
So I turned around and drove back through the forrest.
Drove through the forrest and through a paddock (Id say field, but they dont call them that over here) and down to the campsite which was a lovely spot with a river on 3 sides.
Set my tent up and attempted to cook dinner, only to discover the gas cylinder I'd bought was empty. :doh:
Fortunately everyone offered me they're gas/stoves, so dinner was saved. :icon-biggrin:
The night consisted of everyone sitting round a huge campfire. :violin:
And of course plenty of bottles of TED. :dance:
Breakfast time.
The beer and steak here are really really good. :clap:
But the sausages are terrible. :thumbdown:
These tasted as bad as the look. :icon-rolleyes:
Apparently there is a butcher in Dandenong that makes and sells English sausages, so I will have to try and source some for the next trip. :icon-cool:
The property we were on belonged to one of the club members who builds and drives challenge trucks. :icon-twisted:
Up until 5-6 years ago they used to host a lot of events here. :icon-biggrin:
Then the state goverment changed the law so that motor sport events can only be held at race tracks. :icon-rolleyes:
That law is due to be scrapped in August hopefully, then events can start again. :pray:
Anyway a few of the guys had offered to show me round the property. The rock garden sounded particularly exciting. :icon-cool:
Aired down to 20psi.
Emptied all the stuff out of the back and I was ready. :icon-twisted:
Before we set off I had a chat with one of the guys who owns this lovely 60 series.
He has owned it for the past 20 years and because it has been regularly serviced and maintained it has never broken down or needed any major parts replacing. His mates one has just done 1million k's (600,000 miles) :icon-biggrin:
Anyway.................back to the tracks.
I followed Dean in his Patrol tray back.
The pics dont really show quite how steep a lot of the terrain here is.
This is the rock garden, which is the start of a creak and runs all the way down the mountain. Its atleast 1km long, although I dont think Id be able to drive all of it because its too extreme.
Its very similar to the new rock section at Lincomb, but obviously this one is natural.
Very overgrown as it hasnt been driven for a few years. Once they do another event here everything will be opened up again.
The owner had said we could drive anything we wanted, and if we got stuck any where, we could cut trees down and make a new track to get out. :icon-biggrin:
I decided not to attempt it without my front locker and winch, but next time I will definitely be attempting it. :icon-twisted:
John, the guy running the trip drives this lovely 80 series.
The guys then took me to one of the tracks I saw when I first got to the woods. A steep rutted, rocky climb that looked very extreme. :icon-twisted:
Had a wonder up and this is the view back down.
The only person there not driving a LandCruiser or Patrol was Craig in a disco. He was going to attempt the climb in his twin locked disco, but decided against it. Probably a wise decision as I struggled with 37"s. :icon-twisted:
We moved the trucks around so I could attempt the climb.
I aired down even further, this time to 15psi, and off I went. :icon-biggrin:
I came to a stop a few times, but by backing up a little and changing lines slightly, and plenty of right foot she got quite far up.
The rear locker did a great job, but as I didnt have the front one fitted it was a struggle. I reached one point where 2 tree roots were going across the track and try as I might I couldnt get over them.
They can be seen quite clearly on the pic below.
One of the guys had come with me and he used his hand held radio to radio down to the others and tell them we needed the chainsaw.
I wanted to cut the fallen tree out of the way on the side of the track, as I was sure without that there I could take a different line and avoid the 2 tree roots which were causing me problems.
I wondered down to meet the others, view back up.
Tree cleared and I shot up the track. The next section was very rough, and as I had no winch, and knew no one would be able to get to me, I had to make it through. Going back down back wards really wouldnt have been an option.
So I gunned it in first low and was convinced I was going to hit one of the trees with the rear quarter panel, but luckily I missed it. One of the front wheels then bounced up 2 ft into the air which was pretty scary. But I made it through and up the track. :dance:
I'm hoping some of the guys might have got some good pics/videos because it was pretty mad. :icon-twisted:
I managed to find my way back down to the guys and we set off so they could show me some other challenging bits.
They showed me a few tricky rocky sections which I drove while they all watched which they seemed to enjoy. :icon-smile:
I then popped a wheel in the air and jumped out to take a few pics.
I then found I couldnt reverse as I was against a bank, and forward wasnt an option as the wheel off the ground was just getting higher and higher.
So a quick winch pull was needed.
We had a walk round and looked at some of the tracks going up the hill. I'm not sure I would have attempted any of them in a 4x4. One was like a shear cliff face, the challenge trucks must have had to winch the entire way up. It was that steep I think it would be a struggle to get up it on a trials motorbike. :icon-surprised:
One of the guys turned up in his lovely 70 series. :drool:
We then went back to the camp for lunch.
We then spent the afternoon drinking and chatting round the campfire till the early hours. A great bunch and a real mix of people. The youngest was 6months and the oldest in their 80's. :icon-biggrin:
Today (Monday) was much clearer and warmer. View from the tent.
A lot of the guys were cooking on these.
There called biji's and worked very well. :clap:
http://www.4wdshop.com.au/equip/bijibarbi/
Had a good look at John's 80 today and had a chat with him about the different mods hes done to it.
Hes fitted a top mount intercooler in order to get EGT (exhaust gas temp) down. I asked if hed got an EGT gauge which he had and I told him its not a very common mod over in the UK, but I know a lot of 4wders do it in OZ.
He said its because when your driving in the desert and its a 40 degree day, the EGT can get dangerously high, obviously not a problem in the UK. :think:
Took the tent down and hung it over the back door to allow the base to dry as it was damp. Also got all my tyres aired up.
With the camp packed up we all said good bye and left. Still couldnt believe they towed trailers, and caravans along the access track through the forrest.
View back up the extreme track that I drove.
Back on the road home. Everything is looking very green now after the recent rain.
And home.
Gave it a good blast over with the jet wash, and while changing the tyres took the opportunity to clean underneath while the wheels were off.
With the trolley jack and air impact wrench and steam pressure washer, it only took 40 mins to clean the truck and swap all the wheels. 40 mins after a trip is quite quick really, so I think thats what I will do in future, but obviously I would be putting the 35" tyres back on and not these tiny 31"s. :icon-cool:
So a great weekend away with some great people. :dance:
Not a huge amount of driving, but loads of socialising which was still very enjoyable. On the next few trips we will be travelling around and camping at different spots, so will do a lot more driving. :icon-smile:
Cant begin to tell you how happy it made me to finally be driving my LandCruiser here in Australia, off road with a 4x4 club! :icon-biggrin: :icon-biggrin: :icon-biggrin:
It finally feels real and I'm loving it! :dance: :flags-australia:
Next time we go back to Bindarree if I've got my front locker and winch fitted I'm going to drive the most extreme tracks I've ever found! :icon-twisted:
Might take all day to drive and winch my way up the 1km rock garden, but it will be so much fun!!! :icon-twisted:
Hoping to get back to the guy doing the compliance certificate tomorrow to show him the new headlights, seatbelts and weld below the windscreen. Fingers crossed he says its ok and passes it off, then I can get it registered and get my Ozzy number plates. :pray:
Well done Ben, :clap: looks like a great place there, wouldn't fancy taking my 80 up that rock track, but looking forward to pics of you doing it. :thumbup:
Looks good!
I've sort of started my planning for my return to Aus; I have somewhere to stay when I arrive, a vehicle (but it's in ACT and I'll be in Northern NSW) and that's it... I could probably do with getting my tickets sorted out soon as well...
I'm looking at 4x4's as the car we have sorted at the moment is an old Volvo (that's my other weakness, and I know a very good Volvo forum with some good Aussie's on it) which won't do the tracks that well...
Good luck with the Inspection; if they only picked up a few things then it should be quite easy to get sorted.
Doesn't surprise me it was a Leb running the yard, have you found that certain nationalities got drawn into certain trades yet? Italians do concrete, Leb's (particularly in Western Sydney) run the workshops, Maltese do security, Irish build things and get the Italians to do the concreting.
Thanks guys. :thumbup:
I called the guy doing the compliance certificate today and he said not to bring it back for inspection until I have the compliance sticker which still hasnt arrived. He said he thought it would arrive today or tomorrow.
Fingers crossed it arrives tomorrow. :pray:
The unregistered vehicle permit expires tomorrow. :thumbdown:
I thought 14 days would have been plenty long enought to get it registered and on the road, but obviously not. :icon-rolleyes:
Anyway.....................................
Been here 2 months today! :flags-australia:
Its gone really quick yet at the same time feels like I've been here for years! :icon-smile:
Ed whats your budget for a 4x4?
Are you planning on doing trips off road?
Not really found different nationalities doing different jobs/trades if I'm honest. But I dont doubt what your saying. :think:
