I must have spent 12 hours now washing sand out of the truck.
I want a new custom aluminium rad and electric fan. But ive decided to wait till I get it to OZ, as not only will I be earning a lot more money, but there will be more choice of reputable suppliers.
Saturday morning I went to the scrap yard and got another electric fan.
The old fan is seized solid.
With the new fan fitted and wired up, I continued trying to get sand out of the floor pan and sills.
I removed 2 of the body mount bolts, as I thought this would help with washing the sand out.
It worked well, and all the sand was now out of that section of the body.
I found the best method for removing the remaining sand from the sills, was to push the hose inside the sill and push it up and down the sill vigorously until the water ran clear.
Sunday morning I was greeted by the first frost of the season.
First job was removing the rear bumper.
No surprise loads more sand.
Ive been planning for a while to swap all the bodylift spacers, rust kill and dinitrol, and sort out the dodgy electrics.
So this stripping down and cleaning as a result of getting stuck in that puddle at Lincomb has only spurred me on.
So one thing ive been meaning to do is move the wiring loom that runs along the rear chassis cross member.
MR T in all his wisdom thought it would be a good idea to bring the wires out the bottom of the driver side rear quarter panel, run them along the chassis and then back into the body at the bottom of the other rear quarter panel.
More on that later though. first i needed to change the body lift spacers.
Popped the plastic caps out of the body to give me access to the body bolts.
I remembered them being a bugger to get to last time, when I did the bodylift, due to the fact the holes arnt directly over the bolts.
After trying various things I had an idea.
Cut the end off a 17mm spanner.
Clamped it at 90 degrees.
And welded it on.
Worked faultlessly!
With the bolts removed I could wash more sand out.
New bodylift spacers, which I bought a few weeks ago.
Jacked the body up.
Stuck a few blocks of wood under, just incase the jack should slip.
And started removing the old spacers and fitting the alloy ones.
Body lift spacers all fitted.
Removed the section of wiring loom from the rear chassis cross member.
It will eventually run along the floor pan from one side to the other.
Stripped all the conduit and tape from the loom.
Pressure washed all the mud and crap off the loom and hung it up to dry.
Ive had problems with the rear lights for a while, and the passenger side hasnt been working all lately.
Removed the light and this is what I found.
The main problem ive found with these cheap aftermarket lights is the bulb holders.
They dont seal very well against the light, and the bulb holder for the twin filament bulbs doesnt fit the bulbs properly. So generally ive had either stop or tail lights but not both at the same time.
So what I need is genuine toyota bulb holders.
Then I remembered the 4 runner lights were still in the shed, and luckily they still had the bulb holders.
Quality bulb holders.
These genuine ones have a rubber O ring to seal to the light and keep water/mud out.
The holes were very slightly different on the 4 runner lights.
A few minutes work with a file and they fitted perfectly.
Ordered a load of stuff from
http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
Hopefully the bits will be here tomorrow and I can finish sorting the wiring out in the back of the truck. All joins will be soldered and heat shrinked.
Once thats done I can rust kill and dinitrol the back end of the truck and inside the floor pan, and then re-fit the drawer system and everything else inside the truck.
New alternator will be here this week.
Then I just need to change the blown CV, clean the crap out from between the wheel and tyre on the tyre that I popped off the rim at Lincomb and re-inflate, and its ready for the extreme laning and wild camping trip which im organising for a few weeks time.
