Busy as a busy thing today. All went pretty well, no major foul ups. Just some jobs take a long time. Weather was perfect so worked til 20.00; basically til I couldn't stand up anymore.
Started by pulling out the rear heater pipes. In places they were fine. In others they were on the edge.
This allowed me to pull out the AC pipe. After a quick search, I found a pin hole just where it rubs on the bulkhead. Damn and double damn.
Nabbed the one off the mud plugger and put that in. The 24v has a joint in the middle of that pipe. The 12v is one long toob. But with the heater pipes removed it dropped straight in.
Then came the heat exchanger install. This began with mounting the pump in line with the supply from the block.
Then coupling up to the heater valve.
The rest was just a question of feeding pipes down the bulkhead and securing them until they appeared through the floor in the cabin.
Then I was ready for a water test. Now the engine only ran for a few minutes but the pipes were hot. The Kenlowe pump is quiet and certainly does push the water round. You can see the effect when you look in the rad. Handy for bleeding the system!
Also the volume of water I pumped through the exchanger was too much with an open pipe and it passed through the unit too quickly. The tank lasted like a minute. But it was luke warm. I shall get all they secured and go again but I need some 90 degree elbows.
That's the end of that chapter. Time for tea and onto the brakes
