Chris, absolutely everything I have read and watched says that props should be phased in line. The FSM shows only in line props too. If it was supposed to be an 1/8 turn out there would be some sort of data, measurement etc to be able to rebuild a prop that had been pulled apart. But there isn't. Everything says they should be in line. But not one of my 4 props is. This is what is baffling me. Pretty sure the green one is un touched and I am sure that knowing the PO, he would have put it back as it was found if he'd had the prop off for any reason. I set my rear prop in line the other day, which wasn't far out and I could tell an immediate difference. I won't say how fast I got up to, but it was quite fast and I seemed to get there very quickly. All seemed fine. I got back and the next day set my front prop in line as well and although it drove OK, I immediately noticed a speed related dub dub. Due to Christmas day and whatnot, I haven't been able to driver it since. I have set the front to 34 degrees as I said earlier just to get me back to where I was before. I will drive it tomorrow and see if that's gone. Frank is indicating something along the lines of setting a prop off by a few splines is how the 80 is set up to compensate for slightly divergent flanges. I don't see how it works. These types of UJs work on a 90 degree in phase, out of phase relationship. IE you can turn them 180 degrees and they are still in phase but turn them 90 degrees and they are out of phase. Turn them 34 degrees and..... Well and what? They are not in phase but they are not precisely out of phase either, but now they are lopsided. Unless it's a very clever balancing act between phase AND the UJ angle when angles are different at each end.
If you take a prop with a UJ and put an angle on it, the drive flange turns at a constant speed. But the prop speeds up and slows down in a cycle. We know that. If the other end goes virtually straight into the diff, this means the diff end is speeding up and slowing down just like the rest of the shaft. You HAVE to have the same angle at the other end to cancel that. So, is the 34 degrees a cunning way of achieving that? Well, looking at my auto diff flanges today they look parallel to each other so why the heck would you do that?
I'm really looking for a definitive but simple answer. How come the FSM makes no mention of it at all?
