.......Why does the ECU turn off the ABS when the rear diff lock is engaged :?: :)
sae70 Well-Known Member Supporter Joined Aug 10, 2010 Messages 2,662 Garage Country Flag Aug 23, 2010 #1 .......Why does the ECU turn off the ABS when the rear diff lock is engaged
Ian Rubie Moderator Joined Feb 24, 2010 Messages 925 Country Flag Aug 23, 2010 #2 Because it has no way of modulating a single wheel when the diff locked. Ian
sae70 Well-Known Member Supporter Joined Aug 10, 2010 Messages 2,662 Garage Country Flag Aug 23, 2010 #3 Ah Of course So what happens to those who fit after market diff locks that also have ABS then
Andrew Prince Well-Known Member Joined Feb 23, 2010 Messages 2,232 Aug 23, 2010 #4 Normally you would use the difflocks in low range, so ABS would (normally) be switched off then. So it's unlikely to be an issue.
