There is a good youtube tutorial on changing one over to the new longer type by Fourby4diesel , would be easy to put the spacer wrong way round without watching Ants video on fourby4diesel .
Well that was interesting. I replaced the SCV, and it's now worse. Just sitting there idling it now this a P1229 and occasionally a P0088 error code. I'll need to contact PF Jones and confirm they have sent me the correct one. I'm so irritated I just packed it all away. Will put the old one back in tomorrow.
Sorry you've had that sh/t Tony, to replace an item with new and find it worse, is more than irritating mate,
Then it's compounded by having to do the job again, Grrrr...
I would try Karl's solution first, as easiest option without any further dismantling, apart from that, as you said it can only be the wrong one, there's nothing else to it. Good luck with sorting it.
The part looks the same but it is not OEM, so came in a brown box. Was half the price, but it should still work, just perhaps longevity being questioned.
Wiring seems fine, but I'll double check it before removing it. Good thing is I should be able to change it out in about 10mins now....
I have the same part as you Tony and have not fitted it yet , PF Jones claim that the part is genuine Denso , I shall fit mine with in the next few days and see what its like ,
Tony I have looked at the part number on mine and it is 04226-0L010 and is for the euro 4 spec , it differs from your scv in your pic by mine having a top cover on the valve like the one Ants on his video in which he clipped on , but mine is already clipped on like Karl has shown in his pic , you need to find out if the part you need is right for your 120 for example is your 120 euro 3 or euro 4 spec as that will make a big difference and hence the P codes .
Good spot Tony, the part number supplied is 04226-0L020, so different to yours. How do I know if my 120 is euro 3 or 4. I did send them my reg and asked which is the correct part and they said the one I got. Hmm
Tony the pic of your scv has a different valve head to that of the pic on PFJones online pic with a spacer , the one you have in your pic is missing the cover that fits over the valve for the 120 models . looks like PFJones could have sent you the wrong scv due to you needing Euro 3 or needing Euro 4 or the scv is missing the valve head cover that fits the 120 , if you can find out what euro spec your 120 is it will help when talking to PFJones ,
I dont remember how I found out mine was Euro 4 , I dont know if it was on the UK log book maybe or some other paperwork , but I remember seeing it some where could be when I put the VIN number on a part site ,
Just checked and they sent me the euro 4 version. I told them I needed the part to match 04226-30010, which is the same as Karl's one, so they gave me the wrong one to order. I'll call them on Monday and get the correct one sent. Will be interesting to see if they will give me a refund for this one seeing as I have used it....
My view: You relied on their expertise supplying the parts, so they have no choice but to take it back because it was their mistake. Lucky you aint charging them for the fitting time!
Euro Emission Standards describe the acceptable limits for exhaust emissions of new vehicles sold in the EU. We cover the Euro emissions standards Euro 1 – 6 that have been introduced so far and also included is a free online tool to check the Euro emissions rating of a vehicle.
