- Mar 1, 2010
1. Undo the nuts and remove the washers.
2. Using a flat punch and hammer hit the cone at right angles to the stud. They ping right off easily.
It's no use hitting the stud, that just grips them harder.
It's no use hitting the flange outwards, that has the same effect.
It's no use hitting the flange at right angles as it is dowelled to the hub and won't move.
Frank
Frank
