CJBNomad8654
- Jan 6, 2013
I was taught that at a minimum you should have a winch that will pull 1.5 times the vehicle weight when fully loaded.I am outfitting a 1997 LC 80-Series for an overland trip. The factory weight is 2500kg. That alone is already a bit over for an 8000lbs winch. This suggestion is supposed to be a straight line pull, not with the cable doubled back. So, if I outfit the vehicle with the ARB 80 Series front bullbar with Warn winch, ARB rear bumper with wheel carrier and jerry can holder, 166l fuel tank, two Outback drawers, 70L fridge, cargo cage, dual battery system, compressor, roof rack, RTT, and necessary recovery accessories, what size winch do I need? For some reason ARB does not list the weights for its bumpers, bullbars, or accessories so I am asking for peoples experience and whether they have weighed their vehicle when fully loaded. I'm asking because the store I am at is trying to help me save some money on the build and said the 8000lbs would be enough, but according to the recommended size that is barely enough to pull the factory - showroom floor - version on the 80 series.
