Mmmmm......what to do
I should be calling Supertyres this morning & ordering my 255/85/16 KM's but I've started to get cold feet again but this time not over the tyres or even their size (skinny) but now it's over wheel spacers
Just before I was off to bed last night I did a quick search on here for wheel spacers & found alot of strong feelings with regards to the fitment of them or not
You see I was just going to fit 'em as advised by Paul @ West Coast & Chris on here but if I don't have to I shant
Matt (24Seven) is running the 255's without wheel spacers & from what I've seen of his truck in photos it looks sweet
Big clean Green is running wheel spacers, Jon Wildsmith is running 20mm spacers, Chris use to run spacers on Lil-Blue not sure if you are now
Dave wall is, Silvercruiser is/was (why did you remove them
), Cossack definetly wont ever again I shouldn't think
Dave Wall is running them
Mmmmmm.....confused a bit
It does look as though wheel spacers give the most trouble to 80 owners
Is this the case
Have any 90/95 owners running 30mm spacers had any troubles as a result
You see I could order my 255's today, have 'em fitted tomorrow, live with 'em for a while then fit spacers if required to help improve looks, COG, stability, turning circle etc
There are alot of pro's & the only con is reduced wheel bearing life
Don't get me wrong this is not good but.........
Mmmmmm..........
Or get 285's with no spacers & be done with it.......
Will 285's fit without spacer
I can't remember now
