sae70 said:.....Chris use to run spacers on Lil-Blue not sure if you are now
Not running spacers on LB
Just got back in from dropping all of the kids to school & nursery Going to make a quick mobile coffee then leave for Supertyressae70 said:No going back now Just got off the phone to Supertyres Five 255/85/16 BFG KM2's Will be waiting for me to get there from 09:00hrs tomorrow morning
Chris said:Actually just very slightly over 33" but not by much. When you run all of the sizes through the tyre comparator this size on the 33" series is the tallest IIRC
sae70 said:I've always run the Cooper STT's in the past & have been very pleased with 'em but they are not available in the 255/85/16 size But you no what they say a change is as good as a rest & I'm really loving the look of the KM2's
Here's something prety sad I did for myself the other evening
265/70/16 30.61/10.43/16 standard fitment
265/75/16 31.65/10.43/16 increase in diameter over std fitment 26.42mm extra ground clearence over std fitment +13.21mm (+13.21mm)
305/70/16 32.81/12.00/16 increase in diameter over std fitment 55.88mm extra ground clearence over std fitment +27.94mm (+14.73mm)
285/75/16 32.83/11.22/16 increase in diameter over std fitment 56.39mm extra ground clearence over std fitment +28.19mm (+00.25mm)
255/85/16 33.07/10.04/16 increase in diameter over std fitment 62.48mm extra ground clearence over std fitment +31.24mm (+03.05mm)
This of course make no allowance for how these tyre sizes are effected by rim width & inflation pressure
Of course I can Chris Anything for you sir I shall do it tomorrow afternoon m8Chris said:Can you get some picks in the arch with the wheel turned. I'd like to see the diagonal across the corners of the tyres in relation to the pinch seam on the arch
Not sure yet as not had a chance for a proper play & lay under But will let you know asap Will tomorrow afternoon doAndyCook said:no rubbing on full-lock with only a suspension lift?
Chris said:Ahhh. Now we're getting somewhere
AndyCook said:that looks great - proper proportions
Thank yousilvercruiser said:Thats better its looking cool now
Posted them herehttp://www.landcruiserclub.net/foru ... 028#p59028 hope you don't mindChris said:Can you get some picks in the arch with the wheel turned. I'd like to see the diagonal across the corners of the tyres in relation to the pinch seam on the arch / firewall
BIG clean GREEN said:Just out of interest, has anyone with the ironman lift towed a caravan, and if so what was it like and did you need to fit a drop plate ? What was the total cost for the rubber and lift SAE70 if you don't mind me asking ?
Nick.
