It's probably rotted off the bottom of it by now Clive so I shouldn't worry.It wasn't the colour that was the problem Chas...![]()
I know, I know.It wasn't the colour that was the problem Chas...![]()
Just got home from Julians house, full service plus a couple of small jobs, one of which was fix my inverter which wasn't playing, IT WAS A BLOODY FUSE I didn't check firstAppointment with Julian V tomorrow for a pre Romania service.
I've got no idea, it was when I tried to use the microwave and found it dead the only thing that's been used on it was the microwave it's a 40a fuse and I don't think the microwave takes anything like that.Ahh but why did the fuse blow Chas?![]()
You speak the lingo better than me Rich so if you can get the (antenna and a bracket to go with it ?) we can just split the cost if it suits you .
Ah hang on! maybe a Romanian river had something to do with it.
I carry mine inside the car all the time when it's not actually in use, the mount end goes in the passenger footwell and the mast slides through to the back edge of the rear seats, it doesn't get in the way of passengers feet. (mind you I don't have the rear seats fitted, but it should be able to slide alongside them if they were there)I can't imagine how you'll carry it, maybe roll it in with the fox wing Rich, it's huge.
Now then, now then, it's all very kind of you and very much appreciated, but neither of you were listening were you?
Aerials need to be of a certain length to match the wavelength they need to be used on, they can be made shorter by using a coil in the base to make up the necessary length. It looks as though that is what's been done with this one but it is still quite long, 165cm, mine has a shorter base and is 200cm and it is more expensive, you pays your money and takes your choice.
