OK quick update time. Not moved more than 5 feet today, been tied to the lathe. I was only going to have one pivot on the bumper then some bright spark, who shall remain nameless, suggested that I might regret that later. So after a sleepless (not) night, I cracked on this morning.
Started with a piece of bar which needed cleaning up quite a bit to get it into a reasonable state for rough machining. Once I'd done that I started with the bottom bearing.
Then the top bearing
Then the 20mm threaded section
The shroud from No 1 carrier fitted perfectly on the new spindle
Then I started the new shroud
Milled in some internal cut outs for removing the outer races
Bottom bearing in
And seal
And lastly, the top bearing. All went together nicely and interchangeable with other spindle which is good news. I must be improving.
Whilst I was working, a courier arrived. Mystery parcel. Hmm, could it be the items I won on e-bay yesterday afternoon? No ......
Yes! Nice tidy bottom arms. Easier than treating rust - just replace the parts.
Bottom bearing in
And seal
