Ahh, in that case Stu, I don't quite follow your plan. You need a shaft that doesn't move and a shroud that does. The shaft has roller taper bearings on it top and bottom. Not clear on which bit you'd substitute to make it quicker. Making the shroud bit is actually very easy and quick. The time is in removing excess metal off the shaft pass after pass after pass. Do you mean that slot in replacement wheel bearings that come in a tube? Our Corolla has those. Throw away unit. That wouldn't save me any time really and as the last one I bought was £60 it wouldn't be viable. It would work in principle that yes. But you'd have to pull the bearings out when you came to weld it.
Worth thinking on though. But like I said, it's the shaft machining that's the time consuming bit which you'd still have to do. Unless you could get the stub axle too and weld that straight onto the bumper. You get tremendous flex even in things that look solid. The leverage effect is huge. The best way is to g through both planes of the bumper for sure. The hub one I made has been good actually, I didn't shut it properly and reversed it in a tree several times without realising. That's why it bent. It was the pin, not the mount at all. Just the pin. We put the tyre on, I climbed up on top and bounced up and down until it was straight again. Pin possibly a bit soft.
