Chris said:yadda yadda yadda.
C
The grey one, or MINEwarrenpfo said:has she got a name yet?
The rear diff pinion is weeping. There may be a leak in the PS pipes at the front, still to identify exactly what's leaking there. There is a small amount of oil on the sump and back to the bottom of the bell housing, still to identify if that's engine rear crank seal or just the sump plug needs nipping up. I've had the sump plug weeping in the past but I'm expecting not have an easy life on that one and have to change the crank seal eventually. torque is a bit lacking low down but that's quite typical for a 24v and will be sorted by pump tweaks and an intercooler. Handbrake could use some adjustmentChris said:Spotted anything major at all? AC aside that is?
