OME or Ironman Coil Springs??
superformance
I need your help guys to decide what should I get between the two brands.
Planning to have 2 inch lift / factory alloys with Cooper STT's 285's, mostly urban driving (some pot holes, uneven pavements), will be installing an ARB bumper. Currently have Rancho 9000X's all round.
Here in the Philippines, OME is more expensive (20%) than IronMan but would love to hear some advice from you guys.
Many thanks!
On my second truck with Ironman, no issues :thumbup:
Well I run OME and always have, even in my Land Rover days. Never had a problem. I have a friend who used Ironman on a 70 series, they lasted 6 months before he removed them and fitted OME. He still has the OME fitted 3-4 years later.
my OME shocks & springs still going strong, even after lost of abuse / overloading
Andy
I still haven't changed my front springs since I had my cruiser, and it has 155,000 miles on it.
superformance said:
Also, should I use castor bushes for the 2 inch lift? And spacers in front?
Some say they're not needed, but when I had a 2" lift the steering was a bit 'vague' which went away after fitting CC's.
Mine is still standard as far as the bushes. But I do have some Slee correction plates to fit one day.
im going to remove the ironman lift kit off my 70 at some point and change it to old man emu or dobinsons.
not very impressed with my ironman kit. :?
OME kit has been fine on my 95-series
front a bit high at first, but swapped for slightly softer springs and has been good since
With respect to all the posters, there hasn't yet been a single post which actually compares the two from anyone who has had both.
I initially had OME on my Defender and it was great until I started carrying weight in the back. Couldn't get the set up right at all after that, it was too stiff and bouncy, handled poorly on the road and the rebound from the shocks was just too much. In the end changed to Iron Man B springs and nitro shocks and it was SO much better. Better road handling but still a sharp turn in, less bouncy, yet still compliant offroad, and no rear sag. This was with front winch, big bumper etc. The vehicle sat level.
My 80 has Iron Man Nitro shocks and C springs and I can't find fault with them at all. I find the biggest difference to handling and feel is caused by playing with the tyre pressures. At 35 psi all round yes it's great for carrying weight but it's just too bumpy, I feel every pebble. At 30 psi all round it's brilliant. Just the right about of rebound from the shocks, stiff but not bumpy, handles well on tarmac.
But I would say before you start saying this one is poor, this one is great etc, just have a look at the weight you're carrying, your tyre pressures, your driving style and the terrain you're using it on. As far as I'm concerned, the biggest benefit with Iron Man is that it's so much cheaper than OME, for a product which is pretty much the same yet you can play with the spring stiffness by choosing different types that the firm offers and they're matched to the shocks. I guess everyone on here knows that West Coast is the sole importer of Iron Man, so I would say talk to Paul about your intended use before you start buying OME.
And to the guy who has an Iron Man kit and is "not impressed" with it, you don't say why, but again, I'd say talk to Paul before you whinge on the internet, I think you'll find him pretty helpful.
Dobinsons
But I do agree with what Mike54 said. Springs need to be chosen based on the loads you are carrying and the type of driving you do and your tyre pressures.
